MBPro Retina display glitching bad without having suffered impact
Dear people,
I write you in desperation because I’m in the middle of exams.
My MBPro Retina late 2013 display is glitching severely without apparent cause (such as impact, fall, liquids, etc.) My heart —and wallet— is broken, as I had already replaced the Display Assembly through the iFixIt store itself.
When I gently pressed the sides of the display, the problem was temporarily solved (1 minute), but now it happens again as a more distinct and periodic pattern: it flickers for 3 seconds and then 2 seconds and a half, a wave of ‘dark blur’ transverses the screen from right to left. Unfortunately, in the background I can see vertical lines that apparently mean hardware failure. These happen during the ‘wave’ phase. Herein I post two videos…
Please, tell me this can be fixed without having to buy another Display Assembly. I’m just a Uni student…
2条评论
@gusguz - You'll need to make another set of recordings using your iPhone. All I see is an out of focus graphics. I don't see any dark blur issue.
How does the external monitor look? I would check things with it.
由 Dan 完成的
@danj Thanks for noticing that, Dan. I don't have an external monitor, but I'm afraid that if that screen video captured graphics just fine, then it is obviously a hardware problem, and I cross fingers that it can be solved by checking the video cables. This problem just started happening out of nowhere!
由 Gus Guz 完成的
