跳转到主内容
加入维修社区 - 创建账户
此为等候许久的Mac mini硬件更新。处理器方面支持选配3.6GHz四核i3,3.0GHz六核i5,及3.2GHz六核i7英特尔CPU。
2018 Mini doesn't boot after RAM upgrade
Hello,
I have upgraded my newly purchased Mini to 16GB of memory. This is the memory I purchased:
https://www.amazon.co.uk/gp/product/B071...
Unfortunately my Mini doesn’t seem to boot now :( The LED turns on, but no display is output. Furthermore, after a minute or two I can hear the fans restart and the LED goes off and on so presumably the mini is constantly rebooting.
Firstly, the above memory should be compatible, shouldn’t it? Secondly, does anybody know what I possibly could have done wrong? I’ve no idea what has happened as I thought the upgrade went OK. Is this symptomatic of me forgetting to plug anything back in, for example?
Very sad about this :(
Thanks for any help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Alright, resolved now. Memory wasn’t seated correctly.
这个答案有帮助吗?
得分 2
2条评论:
Thanks for coming back with that update! I was panicking a little after my initial repair attempt was unsuccessful but your comment helped that a lot. I just went in and seated the ram better and it worked like a charm.
完成的
Same happened to me. The rubber guides on the ram retainers sometimes won't go back to how they were without a little jostling once you have put the new RAM in. After booting to a blank screen; I nervously re opened the mini and checked the seating, now everything is working fine.
完成的
添加一条评论
添加你的答案
Matthew H 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 35
总计 2,020
