跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
112 个问题 查看全部
will not read games
I'm having a problem with my DSI XL. It will not read any games. I've cleaned the games, I've also did a system update. It still won't read any games. I don't know what do anymore. I'm afraid its broken but I just wanted to get another opinion. thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
I am having the same problem!
完成的
添加一条评论
1个回答
最有帮助的答案
either:
1) the pins that make contact with the game are bent/broken/dirty. look into the reader with a flashlight and see if anything's going on. rubbing alcohol + small brush will take care of dirt. tweezers can take care of a bend. broken pins will require a new reader to be soldered in
2) bad solder joint between the reader and the main PCB. Reflowing is a pretty easy job if you have the tools, a replacement is a little more complicated.
good luck
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Camille 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 1,809
