Why won't my laptop won't start when it isn't plugged in?
When I try to turn my laptop on when not connected to AC power, it doesn't turn on. When I connect it and turn it on, it shows a battery full and charging symbol. It is a Windows 10. Help a brother out.
4条评论
Hi,
What happens if you disconnect the charger after the laptop has started and booted all the way to the Windows desktop?
Does it stay on or turn off straight away?
由 jayeff 完成的
@jayeff the screen goes black right away and it shuts down (most of the time). Sometimes nothing happens, sometimes it also turns on without any charge connection.
由 Ahaan 完成的
Hey Ahaan!
The system wont let me post as an answer for some reason, maybe it's because I just joined or something?
Anyway, how long have you had the laptop? It sounds like that the battery may be dying out or shorting out somewhere from the batter possibly being old. Since your using Windows 10, would you be able to do the following steps and see if it reports anything wrong with the battery?
-Access the Windows Powershell as an admin
-Type or paste in the following in bold which will run a report and tell you where it is saved: powercfg /batteryreport /output "C:\battery-report.html"
On the report, I would check both the battery capacity history and the battery life estimates to see if the battery is on it’s last legs. I don’t believe that it will show you anything if the battery is shorting out but this can be one more thing to possibly rule out.
由 Suede Young 完成的
@Suede Young Hello thanks for responding.
It just gives me something that says that the written message isn't a valid one. I hope this gets resolved and how can I make sure that I need a new battery?
由 Ahaan 完成的
