跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1198 个问题 查看全部
iPhone X Face ID not Functioning Properly
So I recently ran into a problem with my iPhone X. I replaced the screen and the Face ID setup won’t work. I have transferred the Serial Number over from the original screen so true tone is functional. No errors come up, it is able to get into the part where it asks you to align your face with the frame. However, it just asks me to move the iPhone a little higher and then a little lower. It won’t actually detect my face but it knows a face is there because if I move my face out of the frame it says that the face is out of view. I have tried cleaning the IR cam, front facing cam, flood illuminator and the dot projector with 99% isopropyl alcohol.
  • Animoji is fully working
  • Portrait mode from the rear facing cameras work but not front facing
  • Face ID setup won’t complete
Anyone ran into this problem and managed to solve it?
Thanks, Andrew
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Check out the two guides and you might know why
为什么维修iPhone后面容 ID会失效
如何修复 iPhone 面容解锁的“高一点 / 低一点”问题
iPhone X图片
指南
难度:
中等
iPhone X图片
指南
难度:
中等
这个答案有帮助吗?
得分 1
添加一条评论
iPhone XS Max Face ID Not Working Fixed - Dot Projector Repair
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Wilson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 486
