跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1989,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
210 个问题 查看全部
MacBook Trackpad works but doesn't click. (Liquid Damage).
I recently spilt coffee on my MacBook trackpad, quickly tried to wipe it off but some of it seemed to have seeped through. Everything works properly, I haven't had any issue with the MacBook except for the click. The trackpad doesn't seem to click anymore.
I took it to apple and they said I have to replace the whole logic board and the trackpad, and that it would cost me about $1299 which doesn't make sense. After a while the trackpad click started to work again, but only slightly, I can feel faint clicks every time I press down on it.
Should I get a replacement trackpad or should I just try and clean it up once and see if that helps, there are coffee stains inside the MacBook. If I can clean it, How would I do it?
Are there kits from IFIXIT to handle such cases?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Remove the track pad and clean it with alcohol and a brush, and if it does not fix the problem, replace it.
MacBook Pro 15" Retina (Late 2016-2019) Trackpad
MacBook Pro 15" Retina (Late 2016-2019) Trackpad图片
产品
$69.99
这个答案有帮助吗?
得分 2
1条评论:
That's what I was thinking, but I'm not sure what kind of alcohol and alcohol to get or where to get it.
完成的
添加一条评论
I know this reply is way too late to help Rakshith, but it may help someone else. The type of alcohol to use for cleaning is 99% isopropyl alcohol. It can be a little hard to find, but a good pharmacy or drugstore should carry it. If not, it can be found online, although the shipping maybe a little expensive. 70% isopropyl won't work well because there's too much water in it. 91% might work, but 99% is the best.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rakshith Rajashekar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 13
总计 242
