跳转到主内容
修复你的物品
维修的权力
商店
The Dell Latitude 7350 hybrid laptop (model number: Latitude 7350) is a 2-in-1 device that functions as both a laptop and tablet. Released in 2015, the Latitude 7350 is no longer being produced. You can find repair guides and device information here.
6 个问题 查看全部
Both USB ports of Dell Latitude 7350 are not working?
I want to install Win 10 on my Dell Latitude 7350 but there is an issue that it could not be installed. As u know there is no CD/ DVD ROM in this laptop, so there is only one way to install Windows which is through USB. But unfortunately, my laptop is not loading/ picking the windows from USB. I think both USB ports are not working. Please help me that how I can get rid of this issue???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
Check to see if you can charge something through the USB ports, if you can then it’s probably a usb issue or bios won’t boot from it, if they don’t, there might be a blown fuse somewhere
这个答案有帮助吗?
得分 0
添加一条评论
I think your USB port might be fried, so your gonna need a replacement laptop, or just repair it.
这个答案有帮助吗?
得分 0
评论:
Hi @zeku_ ,
It could also be a setting in Device Manager that stops the USB port supplying power to the connected USB device.
Here's a link that explains it. Read the Chosen Solution USB port on the right side no longer work
完成的
添加一条评论
添加你的答案
Abid Hussan 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 17
总计 217
