跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
NO SIM Card bad soldering job
Hey guys, friend of mine brought me this phone without working sim (no sim message in the left top corner). Immidiately after openin, I've recognized something bad about the sim card reader, it’s full of connected solder.. any idea how to repair this stuff? I’have microscope and soldering and hot air station.
Update (11/21/2019)
That’s what I’ve found underneath. Is there a possibility to repair those pads?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Arbaman may be correct about audio IC repair.
·         Clean the solder up so there are no bridges.
·          Check that (*#06#) brings up an IMEI number.
If it doesn’t, remove the logic board from the housing and check the audio IC, you will probably find it has been reflowed or repaired with jumper wires.
 If it has been worked on the most likely scenario is that they have put too much heat on the audio IC causing the solder balls under the baseband CPU to expand and bridge causing the “no sim and or searching no service.” This will require the baseband CPU to be removed and reballed, it is not an easy job.
If the repairer was not experienced they might have thought the sim tray was the problem.
If (*#06#) does bring up the IMEI number and there is no sign of audio IC repair go ahead and replace the sim reader.
这个答案有帮助吗?
得分 4
4条评论:
And repairing the pads under the sim reader?
完成的
I cannot make out any damaged pads. I can only see one image with a lot of solder. Clean the solder up so there is no bridging and check you get an IMEI number and check audio ic. The sim reader may be the least of your problems.
完成的
Even if all the pads are missing it is not that bigger job to run six jumpers. Just run them from J_DEBUG it is only a few millimetres away.
完成的
I've updated the image of the broken pads. The jumper should come from where to where please?
完成的
添加一条评论
If you are skilled enough and confidant enough then i would replace the sim reader, probably save you a lot of time than trying to make the bad one good
这个答案有帮助吗?
得分 1
4条评论:
I would try to repair this one, but it's obviously a problem of the soldering mess inside isnt it?
完成的
@jrkstbl I agree with @danscreens , remove and replace, if there's already such a visible mess you can't rely on what's on the bottom. I wouldn't be surprised it's not the only damage on that board, especially if all started with an audio IC repair.
完成的
Any possibility to rpair the pads? It shows up that the pads under are already tear of the logic board. I can see very small dost of copper probably, is it possible to solder a new material to them? Multiumeter showing nothing when i put a probe on it, buts is so tiny, i dont know if i can believe the multimeter.
完成的
@jrkstbl Try to take and post a couple of pictures, so that we can see what you see. 在已经存在的问题里加入图片
完成的
添加一条评论
Put more flux and re-solder with pencil bit iron.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jrkstbl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 374
