Car vibrate at 70-90 km
My car vibrates at 70-90 km and once I cross 100 it become completely normal, I thought it might because if tires balancing but I got the balancing done and it still continues, does anyone know what’s the problem thanks
You likely have out of balance CV assembly
These are the symptoms of a bad or failing CV axle shaft assembly
这个答案有帮助吗?
I will have to check with my mechanic.
Jignesh Patel rotate your tires or change your tires. Have a good mechanic check your front end including the ball joints and tie rod ends.
这个答案有帮助吗?
I rotated the tires but still the same problem, in fact, I changed my all-season tires with Winter tires and still have the same problem.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 216
Does the steering wheel also vibrate?
由 Dan 完成的
Yes I can feel it, the whole car vibrates
由 Jignesh Patel 完成的
Jignesh Patel yours the All Wheel drive model?
由 oldturkey03 完成的
No fwd 2.4 litre engine
由 Jignesh Patel 完成的
