跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2189 个问题 查看全部
My phone turns off as soon as I unplug it
i have been following through with the 4s battery replacement tutorial, but this little thing is proving to be a problem. i can’t seem to get it to sit still and it keeps moving around, and the phone only works when plugged in. any help?
Update (11/11/2019)
apparently the pressure contact has nothing to do with the battery, so what is going wrong? D:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Forget the thing that holds down the antenna. If the phone works when plugged in, then that is pretty good for a 4s. It is difficult to find any battery that will still work in a 4s. Use a usb ammeter to see if it is consuming charging current. If it is—wait and the device will eventually work on battery. If it is not, then troubleshooting battery and charging.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
hey:) 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 51
