跳转到主内容
Model A1318 / 32 or 64 GB capacity
394 个问题 查看全部
iPod acting crazy apps close, voice control pops up...WTF?
So lately my ipod has been acting stupid...when i push the hibernate button it makes a camera sound and the screen flashes even though there is no camera on this ipod (does not go to hibernate)..the voice control will pop up randomly and make stupid sounds..when im in the gym it likes to switch songs randomly...the screen likes to shift up when im using the home screen and it displays a few icons but i can swipe my finger down and it will go back to normal. wtf is going on??? oh yeah i restored it back to factory defeault and after restoring it it continued to do the same thing...could this be a virus or is my ipod just crazy?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 3
添加一条评论
4个回答
已选择的解决方案
I don't think it's a virus. Sounds like your home button is shortened out and is causing this odd behavior; hence the snap shot when u press the sleep/wake button and the random closing of apps. Try taking it apart and checking this area and cleaning it out. You might have to replace the home button. Also, do a restore, but restore as new to avoid loading any corrupted files in your backup. This Teardown should help you get to the home button and it's assembly.
这个答案有帮助吗?
按维修分数 2
添加一条评论
first are you pressing the home and sleep button in the same time that makes a screen shot. next there might be something wrom with your home button and there may be something that keeps pushing it like my brothers iphone and there is something wrong with the display have you dropped it or replaced the screen before? the problem might be because the display is not plugged in right hope this helps
这个答案有帮助吗?
按维修分数 1
评论:
No i dont think its a display problem because of all the other things going on with it. like the voice control and all also apps like to close out while in use...
添加一条评论
Did you spill anything on it? Try resetting it back to factory and instead of restoring the back up (which could have the possibility of a virus as you mentioned?) try just running it vanilla, try it on a de-authorized iTunes account so it doesn't automatically restore. If its not being "crazy" then you can deduce that its a software problem. Assuming you didn't do that already.
If you did do it that way, and it still did that then it is most likely a hardware issue, might need to take it to Apple :/
Hope this helped
-JH
这个答案有帮助吗?
按维修分数 0
添加一条评论
your home button might be stuck
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
jasonali10 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 6
过去的30天: 22
总计 11,240
