跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1198 个问题 查看全部
Can I put the working interior of my iPhone x in another body
I recently dropped my iPhone x while skating. It still turns on no problem, but the screen is cracked and at the bottom its bent ever so slightly. unable to swipe up as the bottom half is unresponsive. Otherwise the phone itself seems to be in working order. Is it possible to remove the “guts” (sorry for the gore) of my broken phone and put them in the body of another iphone X, say one thats factory locked and so the person is selling it for $100?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Sure you can. Why not?
You will probably lose your touch ID if you replace the display.
这个答案有帮助吗?
得分 1
添加一条评论
As long as they are the same model the parts should theoretically work together. The factory lock and serial number are probably tied to the logic board.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ChristopherJ 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 85
