Why is it impossible to shift gears when my 1995 Ranger is hot?
I can drive my 1995 Ford Ranger for 30 minutes , and then it becomes impossible to shift gears until it cools for 90 minutes. What is wrong with my truck ?
Update (11/08/2019)
The 1995 Ford Ranger with a 2.3 liter engine has a 5 speed manual transmission.
Auto or manual?
由 sm_vulkus 完成的
Hi @dtennisman ,
Have you checked the level of the transmission oil in the gearbox?
Do this on level ground.
由 jayeff 完成的
Did you rebuild or buy it
由 Noah Byrum 完成的
I will check the transmission fluid level, that seems like an important thing to do. I did not rebuild the transmission, it is original equipment with probably 200,000 (the odometer died 12 years ago), or more miles on it.
由 otrecords 完成的
Noah, thanks for the suggestion, but I definitely don’t grind my gears.
由 otrecords 完成的
显示更多的1条评论
