跳转到主内容
iPad Mini4 Wi-Fi版型号A1538指南 。iPad Mini3的后继版本iPad Mini4 发布于2015年9月9日。
97 个问题 查看全部
Anyone know what part I can use as replacement?
Something overheated when the display broke and I was wondering if anyone know what parts from another ipad I can use to substitute the parts. I am looking for a coil, diode and touch IC.
diode says: 10F40 Y16
touch IC: should be the same as ipad air 2
coil: can’t seem to find the same size on the ipad air.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Have u checked schematics? There u will get values of parts and then use your donor boards schematics to find a match, as the size is not always the case
这个答案有帮助吗?
得分 0
1条评论:
Schematic is the problem, neither zxw or wxz shows parts, it’s an empty board view.
完成的
添加一条评论
添加你的答案
KWH 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 252
