My hdmi port needs to be fixed there is a rod bent can you fix it?
my hdmi port needs to be fixed there is a rod bent can you fix it ?
If you are referencing the pins on the inside of the connector, then no. It can be replaced however. This is best done by someone with experience and should not be attempted otherwise. The connector itself costs less than $10. This is a simple repair for an experienced service provider and should take about an hour if the part is in stock. It takes longer to get to the part than it does to replace it.
Dan
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 38
