跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
910 个问题 查看全部
How do I install an on/off flex cable?
I was replacing my screen on my ipod touch 4th generation. I realized that I had pulled my on/off flex cable to hard and I broke it. I have bought a new one and I am wondering how do i connect it to the connections on the main board?
solder?
adhesive?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
i'd love to know the answer to this... please let me know what you come across
完成的
添加一条评论
2个回答
最有帮助的答案
u'll hav to definitely solder it on, but first u have to remove the main board(pcb) to have enough room to do the job. remove the old on/off flex by unscrewing the 2 screws on the top right power button,reheat the flex for few seconds to remove it easily by heat gun and then remove the 3 screws on the volume button there u can take it off. replace the new on/off flex the same way. assemble the rest of the board and solder the flex. hope this will help.
这个答案有帮助吗?
得分 1
添加一条评论
well you definitely have to solder it on. I'm doing mine right now and I have to clear off the old solder and crap from the 4 solder points. However, they are super tiny so have a good soldering iron and and Exacto knife. Then you'll have to resolder the new one onto the board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Spencer 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,416
