跳转到主内容
Repair and disassembly guides for food cooling appliances including refrigerators, freezers and fridge-freezers.
832 个问题 查看全部
1988 Hotpoint GE no frost refrigerator-freezer: CTX18GKER stopped work
1988 Hotpoint GE no frost refrigerator-freezer: CTX18GKER stopped working. I did find the refrigerator gasket was broken and i did Replaced it . Now the fan inside the refrigerator are working but the air is Hot while the compressor fan start working and stop every 3 second with a click. After few minutes the compressor fan start again and after 3 seconds stop again with a click. I touched the compressor and it has normal temperature. This refrigerator was Uploaded in 1995 do to a recall.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
Hi,
Does the compressor run continually trying to drive down the temperature?
Is the evaporator unit in the freezer compartment icy cold to the touch, (be careful when you go to test if it is or not)?
If the compressor is running and the evaporator unit is not cold then there is a problem in the sealed system.
This could be due to a blockage, a faulty compressor or a lack of refrigerant.
Is there an oily residue below the compressor or condenser coils at all which may indicate a leak?
The high and low pressures of the sealed system will need to be checked by a licensed refrigerator repairer (at least here it does due to government environmental regulations regarding the handling of refrigerants) to find out what and where the problem may be.
这个答案有帮助吗?
得分 2
评论:
1988 Hotpoint GE Nofrost Refrigerator-Freezer CTX18GKER is not working. I did replace a Gasket. When I started the unit in full power (Freezer-E and refrigerator 9) it worked with a 10F. Freezer and a 40F. Refrigerator and started making a little ice. I did lower the power to C and 4- and the Refrigerator stopped working having hot air inside. Pulled the plug and waited about 5 hours. Plugged in the Refrigerator and the inside fan working with HOT air and the fan on the lower right side in the back of the unit starting and stopping with a click doing this every 3 minutes for ever. Compressor not running but the fans start. No oil residue. The Gasket Seals are working fine, ONLY HOT AIR Inside the refrigerator.
完成的
Hi,
Since the compressor is not starting, you would need to check if power is being applied to the compressor motor or not.
If it is then you may have a faulty start winding in the motor.
If it isn't then you may have a faulty thermostat.
Be careful if you go to test for power as there are lethal voltages involved. If you don't know what you're doing, get an expert to look at it.
Here's a link to the partsfor your fridge which may be of some help
完成的
添加一条评论
添加你的答案
ettore lacchei 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 33
