跳转到主内容
Repair guides and support for your Samsung TV.
2606 个问题 查看全部
After 1hour of red led flashing the tv turned on with an issue
Hi,
i have a samsung tv lcd serie 5 from 2012
it have of problem that it turn on after some hours
so, after searching, i found that i need to replace the capacitors on the power board
but the capacitor looks ok, not blown or something
anyway, i replaced 2/8 capacitors
and the problem didn’t fixed and i got new problem which is the colors in the screen and blinking led 6 times every 1minutes for about 1hours(which is better than before that it was taking 4 to 5 hours to turn on)
Another thing
The motherboard have a lot of acid in the back of it, so, i clean it with alcohol 95%
What i should do other than buying new motherboard or power board?
Do i need to continue replacing the capacitors ?
what is the reponsable components for that colors ?
Two boards photos
Appreciate any help !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi M J,
yes, you must exchange all of the capacitors. The capacitors can look fine, but inside the capacitor, there could be an issue. The electrolyte is having some “life cycle” and if the electrolyte is old, it can lose capacity or lose the right conductivity. The capacitors will work fine for about 2 up to 4 years, then they will start losing their electrical characteristics.
The first step in any repair centre is exchanging all of the capacitors, except tantalums. If the issue will still continuing, write below, and we will try to find another solution.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
M J 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 47
