The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
419 个问题 查看全部
My XBOX shuts off after a while when playing.
Could this be an early warning of the RROD? or something else? Also every once in a while the xbox will turn on with video but no sound, or I get sound and no video.
Thanks
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Does it feel really hot?
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
5个回答
已选择的解决方案
This is my answer to Freezing on startup, freezes for anything to do with the guide.:
"This is usually a pre-cursor to the Red Ring of Death, or an e73/e74 error. I suggest installing a Red Ring of Death fix kit, which should fix the problem before it turns into the RROD. Here is a guide that should help you through the process."
And you're right, this is an early warning for the of the RROD.
Xbox 360 Red Ring of Death Fix Kit张图片
产品
$29.99
这个答案有帮助吗?
按维修分数 5
添加一条评论
This is an indication about how much bad your problem will be.
Your XBOX probably is getting so hot.
In some specialized shops, there are some kits to cool your machine.
这个答案有帮助吗?
按维修分数 0
添加一条评论
Open up the box and clean everything including the fans and heat-sinks; and Replace the heat-sink thermal paste. Dirt, dust and putting the Xbox in an entertainment center are almost always the reason for the red rings in the first place.
这个答案有帮助吗?
按维修分数 0
添加一条评论
I agree with a precursor to the RROD, but with it "not turning on with video but no sound, or I get sound and no video" I would look at the A/V cables. Replace them first, then look at the RROD repair.
这个答案有帮助吗?
按维修分数 0
添加一条评论
Ive got the e71 before on my xbox 360 s
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Murmador 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,157
