跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
677 个问题 查看全部
iPhone 8 Plus home button stopped working randomly
I have an iPhone 8 Plus that I replaced the screen on last Thursday. Everything was working fine when I gave it back to the customer. Customer came back in today and said the home button stopped working over the weekend. The screens are Mobile Sentrix XO5 aftermarket. Tried Reinstalling that original screen with the home button, still nothing. I am in the process of doing a restore. Any suggestions or similar problems you have faced?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This problem usually occurs from a small tear in the home button flex from the screen. But you have tried another screen so have ruled out the screen flex. This leads us to the home button assembly itself. You will probably need to put the home button assemble under a microscope and see if you can find the fault, it may be a small tear in the flex, damaged trace on the connector or the turtle IC Either way they are not easy to repair.
It seems strange that the problem did not occur straight away after the screen change. I would also make sure it is getting power to the connector.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
matt mocciola 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 89
