跳转到主内容
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
385 个问题 查看全部
Snapped disc stuck in drive, wont eject manually.
My son, in temper, snapped a disc panicked and push half the broken disc back in, it wont come out automatically or manually (I’ve tried taking off the top and turning the manual screw) I took it to a repair centre who say that the only way to fix is it to replace the drive but that would be expensive, any ideas at all?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
unless the snapped disc damaged the drive, the shop is just trying to get you on a replacement.
it is 100% possible to remove the disc drive and take the drive itself apart to remove the disc. I’d find another shop that is more helpful and willing to work with you on it, removing the disc and charging you a labor fee if the drive still works and if it doesn’t then offer you a replacement cost.
you could also try it yourself, but there are dangers involved for an expensive machine like this. I believe there’s an ifixit guide on removing the disc drive however
这个答案有帮助吗?
得分 0
2条评论:
Do you have a link to the guide? Im brand new to this site I found it looking for any help to fix it.
完成的
添加一条评论
添加你的答案
Shellie Palmer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 711
