No Battery recognized and only one battery led indicator always on
Hello all,
I tried to turn on my laptop and it didn’t start, at all by any means, after reading a lot try to and see the causes, I tried the SMC but it didn’t work, I ended opening my laptop and removing the logic board to clean it up, after that My laptop turn on but I noticed it didn’t recognize the battery anymore, I reopened the laptop to verify I didn’t left any cable unplugged but it seems everything is well connected. My laptop still only working with the charger only.
The other weird thing I’m seeing and I have not had luck to find anything about is that one of the battery indicators led in the left side is always on, and by always I mean always even when I turn off the laptop and remove the charger of my laptop. (See Image Below)
As final comment, I also checked the voltages measures in my battery, I haven’t found the schematics for my laptop but I got readings of 12, 5 and 3.3 Volts in my battery, there is one pin that reads 2.5 Volts not sure if is the communication bus because I don’t have the schematics.
I’m looking for advices to fix my laptop, even if it is an old device it works great after a RAM and SSD Upgrade.
Any advice? - Thank you beforehand.
Update (10/20/2019)
Dan I really appreciate your quick answer. Thanks :)
Tomorrow I will check the module for the battery indicator and will post what I find.
For the battery, thanks for the suggestion, see my screenshot below. Thanks beforehand for the interest on helping me and any comment you may add will be loved.
Another weird thing I see and I don’t understand is below, coconut says the battery is connected but also that is not connected. Thanks
Update (11/09/2019)
To anyone can help me :)
I just bought a new battery but not a new battery checker module, I still having my battery issue, my laptop does not recognize it, the battery third indicator led turns green always and my laptop does not find anything about the battery. See attached coconut battery print screen. Any idea someone can guide me in order to fix my laptop?
Thank you guys beforehand.
2条评论
Your battery is freaking out! There is a small micro controller within it which is failing.
Between the two I'd guess this system has liquid damage. Time to replace the battery as well!
How did you clean your logic board? You may have done more harm if you didn't do it correctly.
由 Dan 完成的
Anybody else who has an idea/opinion about my problem?
I really want to be sure what to do in order to fix my laptop.
Thanks you all guys!
由 Ricardo Carrillo 完成的
