跳转到主内容
加入维修社区 - 创建账户
Zeki 制造的平板电脑的维修指南和支持。Zeki 平板电脑的背面中心印有大写字母“Zeki”。
Why are the lnes in the center of my new able
My tablet has lnes in the middle ts red at times an today it's white have seen v3 lines at times new tablet only a few weeks have seen up to 3 different color of lnes don't have anyideal what to try
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Jerry Hardee  could be an issue with the LCD TAB connection. Post an image of what those lines look like 在已经存在的问题里加入图片 If it is the TAB’s then it is not a DIY repair but needs a replacment LCD
这个答案有帮助吗?
得分 1
3条评论:
bruh I already basically said that why do you need to repeat it?
完成的
bruh? LMBO! I repeat it because your answer is very convoluted and not very clear. Yes, you added the TAB after but seem to forget that things like "pixels to the motherboard" is really very nondescript. The lines maybe a pixel wide but no pixel will ever connect to anything. A pixel is nothing but the smallest unit of a digital image that can be displayed.
完成的
Still have lines will try to find some way to return it hopefully they will repair or replace it
完成的
添加一条评论
this problem is caused by loose cables and no connetion in the pixels to the motherboard aka TAB
这个答案有帮助吗?
得分 0
1条评论:
it can be fixed because if you push on the spot on the edge it goes away how take it apart and push on all edges of screen
完成的
添加一条评论
添加你的答案
Jerry Hardee 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 25
总计 359
