跳转到主内容
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 个问题 查看全部
What's the best CPU I can put in a mid 2010 27 inch iMac?
So I have an iMac 2010 27inch and have an i3 in it, even with a SSD in it it’s a bit sluggish because the CPU just isn’t good enough anymore. What’s the best upgrade I could put in there to make it better? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The best CPU this series had was a 2.93 GHz Core i7 (I7-870) thats the best you can go.
这个答案有帮助吗?
得分 1
4条评论:
Nothing better then? I saw some people talk about Xeons for example
完成的
Xeon's, really! There's more to it than plug and play here.
First the system's power supply needs to be powerful enough to supply the power the more powerful chips of the day needed. While newer chips have gotten better in their power needs by die shrink in the same effort the CPU sockets have been altered and the PCH logic and system firmware likewise will need to support the CPU in question. Nothing like that has happened in this series.
完成的
@danj Yeah I guess that makes sense. i7 it is then! The i3 is really choking up these days now and everything is laggy even with relatively enough ram
完成的
@nar001 - An i7 will be a very good upgrade given what you currently have an i3, it won't be sluggish afterwards ;-}
Don't forget to get your system to at least 8 GB or RAM 12 GB is what I would go for.
完成的
添加一条评论
添加你的答案
Nar001 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 32
总计 797
