跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。相容的行動網路為2G、3G、3G+、4G(LTE)、4G+(LTE Advanced)。A2100僅有nano-SIM,其餘版本為nano-SIM與eSIM。儲存容量有64 GB/25B GB/512GB三種。顏色有銀色/太空灰(深空灰)/金色三種。(機器讀作iPhone 10s)
398 个问题 查看全部
Why is there no incoming and outgoing audio in calls after a repair?
I replaced the screen on an iPhone XS and now the audio does not work on calls. Incoming and outgoing, people cannot hear me and I cannot hear them. Face ID still works and the microphone still works (voice recorder works) and so does the earspeaker (I can hear it when playing anything else.) One last thing, when I place it on speaker it immediately takes it out and still, nothing can be heard.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
If it suffered a decent drop I would suspect one of the solder balls on the interposer board that is connected to baseband has failed in some way. I think you might have to split the board and check. If the pads look all right the baseband ic would be the next culprit.
这个答案有帮助吗?
得分 3
添加一条评论
Same here,
I hope you sorted it out, but I am testing an iPhone XS with the same issue, and if I press and hold the Face ID (and earpiece) cable it works on phonecalls, as soon as I realease the finger from the connector it stops working.
What could it be?
I’ve already changed the earpiece, but with no changes.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Noel Lopez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 135
