跳转到主内容
Samung 28" 4K UHD Monitor. Model #LU28E510DS/ZA.
5 个问题 查看全部
Can I add my spare samsung tv speaker on Samsung U28E510 Motherboard?
I have Samsung TV speakers & want to add these on Samsung U28E510 monitor Motherboard. Is it possible if Samsung U28E510 Motherboard have the audio port to add these speakers? Pls find the mother board picture I found on ifixit site for Samsung U28E510 Motherboard . Is this motherboard have the audio amplify port to connect Samsung TV speakers?
Update (10/13/2019)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Robin Singh  possible but we need to see the main board. You can probably connect it to the audio IC if it is amplified. Post some good pictures of the board with your question so we can at least try to help you further 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
5条评论:
Not a good picture to identify the IC's but that board does not look like it has an audio amp. Can't really see it to well. Maybe take another picture just brighten it up and enlarge it.
完成的
Pls find below URLs for motherboard picture & you can zoom it. https://d3nevzfk7ii3be.cloudfront.net/ig...
Samsung U28E510 Motherboard Replacement
Hope this will help.
完成的
does your monitor have speakers right now?
完成的
@oldturkey03 - No, only one audio jack for earphone. Want to install existing Samsung TV speakers in this monitor if possible instead of using external speakers through audio jack . Thanks
完成的
Robin Singh you can't unless you get an amplifier first. Your board does not support speakers. You need an amp that you could install by the headphone jack and then install speakers. As is, does not work.
完成的
添加一条评论
添加你的答案
Robin Singh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 195
