跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
412 个问题 查看全部
Screen replacement compatible with XR?
My iPhone 11 screen has cracked and I cant find an 11 lcd screen replacement to buy anywhere online to repair myself. After some looking for picture of both the XR and the 11 under the display and the screens itself they look very very similar. Could I possibly buy an XR display and use it on the 11 with it fitting properly?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
XR is not Compatible with 11
完成的
添加一条评论
9个答案
最有帮助的答案
The display modules look the same, but you can’t install the screen from iPhone XR to iPhone 11 because they have technical incompatibilities.
这个答案有帮助吗?
得分 3
添加一条评论
No. They may look the same but they both have something that prevents you from using a xr screen on a 11
这个答案有帮助吗?
得分 1
添加一条评论
Apple is too smart for this trick :) Iphone 7 and 8 screen was working on one phone, but for example in iphone 7 screen from 8 makes phone warm, and this could cause motherboard issues.
这个答案有帮助吗?
得分 1
添加一条评论
Get this, I saw someone post on fbook marketplace a aftermarket screen replacement for XR OR 11!? Look at the photos…
Now, I'm guessing possibly the instructions can be for both and the buyer didn't realize that but I'm going to look more into this and will report back.
这个答案有帮助吗?
得分 1
添加一条评论
There is a way I saw someone put a 11 screen on an Xr but they used some sort of device to transfer serial numbers from one screen to the other or something like that. But don’t trust me I could be entirely wrong.
这个答案有帮助吗?
得分 0
1条评论:
You cannot put and 11 screen on an XR. The device is called iCopy. It copies the true tone information.
完成的
添加一条评论
https://youtu.be/AIgTrL9xbV0
you cannot interchange 11 & XR or vice versa! See video.
connectors are different.
Update (01/02/2023)
After reaserching and actually trying a swap from 11 to XR I found they do not work. So no compatability.
这个答案有帮助吗?
得分 0
添加一条评论
I connected an XR screen to an iphone 11 and the display works but touch does not.
这个答案有帮助吗?
得分 0
添加一条评论
I have also plugged an iPhone XR screen onto an 11 only to find out that the touch did not work as someone else said. You can trim the excess width from the display plug and then plug in vice versa from the way the XR screen is suppose to plug in and then you realize the connectors are the same but again, as someone else here answered, technically they are different somehow bc you end up with no touch. I’ve never had any issues switching btwn series 7/7plus and 8/8plus screens tho.
这个答案有帮助吗?
得分 0
2条评论:
I posted this long ago and recently I have found that they are different FPC connectors on the flex and and the boards, ie sizes do not match. Thanks for your reply. I do know about the 7/7+ and the 8/8+ screens and did you know the batteries also are compatible ie 6s/6s+ with 7/7+, and the 8/8+ I think the X can work for testing purposes as well, not sure cuase I have not tested that yet.
完成的
If you flip the connection around they will plug in but touch won't work. I did this about 2 weeks ago.
完成的
添加一条评论
The screen LCD ( digitizer) look exactly the same but the flex cables are not compatible. So nope you cant.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Splityou4 将永远感激不已
浏览统计数据:
过去 24 小时: 27
过去 7 天: 158
过去 30 天: 737
总计 22,645
