跳转到主内容
加入维修社区 - 创建账户
Trucks for pint-sized construction projects. Founded in 1946.
Why does my electronic Tonka fire truck cut out after 2 seconds
I put the batteries in and it starts flashing, emitting sounds, and then cutting out.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
skallmann that happens with new and old batteries? Does It work again once you remove the batteries and then reinsert?
完成的
添加一条评论
1个答案
已选择的解决方案
Thanks for responding. I’ve replaced the batteries several times. On some other occasions the problem repeats itself , on others there is total silence. So I’ve concluded that it’s not the battery contacts. It always cuts out at the same point.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
skallmann 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 27
总计 542
