跳转到主内容
Released in 2017, the JBL E45BT are wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
79 个问题 查看全部
JBL E45BT name won't appear
hey, i used my headphones as usual in the morning, turned them of, after 1 hour when i wanted to use them again i could not pair it with the phone. i erased all the bluetooth pairs from the phone but now the JBL E45BT name won’t appear in the pairing list. what to do? it turns on as usual,blinking and stuff but the name won’t appear. it’s fully charged. been trying to figure smth out whole day. please helppp
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hold the power slider up for a long time. It'll switch on and then turn off. Worked for me.
这个答案有帮助吗?
得分 13
15条评论:
I had the same problem and that solution worked for me as well. Thank you very much!
完成的
This worked. Yeeeey. I've been looking all over on how to fix the pairing issue of my headset. Thank you soooo much
完成的
This also worked for me. Thanks a lot.
完成的
It worked perfectly, no other reccomendations worked for me besides this. Thank you!
完成的
yess this worked thank you!
完成的
显示更多的10条评论
添加一条评论
添加你的答案
Anano Machavariani 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 2,881
