Bought new charger tablet is not charging
I bought a new charger for my tablet and my tablet still won't charge how can I troubleshoot it to find out what's wrong if it's charging or the tablet
Did you check the charging port for damage? Look inside for bent/missing pins. Also plug in the cable and gently push up and down to see if the port itself is loose.
If you need a replacement port, the process will require micro-soldering.
这个答案有帮助吗?
Did you test the old and new charger for power at the plug that goes into the tablet?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 33
