跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 个问题 查看全部
Black screen with functioning Backlight and screen
My screen went black with a functioning backlight model vizio d32h-d1 . I first plugged it in it worked fine and I began to link it to my wifi network. The display worked fine I was messing around with the settings when I accidentally clicked on a "screen overlay" setting and since then the display turns on but is completely black with a backlight. I cannot access the menu I have tried various inputs my laptop through hdmi 1 & 2, casting, amazon fire stick, chrome cast stick, and nothing seems to affect it. I cannot see the menu or any feature on the screen. I tried the soft reset and unplugging it holding power for 30 seconds and turning it back on nothing changes.
Is there any other method for resetting? Can i unscrew the back and manually factory reset somehow? I’m not afraid of messing around with the hardware i’ve built a few computers I just know nothing about tv’s. please let me know if you can help thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You could try this. Refers to screen muting.
https://support.vizio.com/s/article/No-V...
Generally speaking, the black screen with backlight only is a very common symptom for Vizio Tvs with a failed main board and or corrupted firmware. Just not sure how that would come from messing with settings though.
这个答案有帮助吗?
得分 0
1条评论:
Thanks Joel its confusing me because it was working just fine.I scrolled through display settign and accidentally hit screen overlay. maybe the hardware happened to malfunction as i hit the menu option but it seems unlikely. Does anyone know of a way to flash reset the tv with say a usb drive? or something i can do manually from unscrewing the back?
完成的
添加一条评论
添加你的答案
Kyle Forrester 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 564
