跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Charging issues persisting after Lightning Connector replacement
I replaced the lightning connector via this guide, really good one. However, I still cannot charge my phone, but the mic and antennas work. I managed to charge the battery directly via an activator circuit and I can power up the phone without any problems. What could be the issue? It is the second lightning connector I try and I have had the same problem both times - everything works except the charging port…
Thank you in advance
Best regards
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
More then likely you have a Tristar issue
See this tutorial video
https://www.youtube.com/watch?v=tGPW6d3o...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jennifer Johansson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 37
