跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 个问题 查看全部
Magsafe orange light blink 2-3 times in 10 seconds - not power on but
Hey ,
I’m not sure how this is start (maybe some short in the before adapter - now it fixed)
The Mac is not turn on, I replaced to new battery but same behavior - you can watch this video: https://www.youtube.com/watch?v=YAniGEWm...
While I opened the back cover after replacing the battery I plugged it to the power and tried to turn on, the screen stays black but it’s looks like the fans are spinning and stopping - like coordinates with the orange light blinks.
Please see if you can help any how.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Your system looks quite banged up! Can you give us a bit of history and why you thought the battery needed replacing.
完成的
Nothing special, One day out of the blue it start.
I looked for this behavior on the internet and found some article on unplug the battery and plug it back after 10 seconds.
I did that but without a luck, I also tried to plug the power without battery but still without a luck.
I thought maybe a short in the power adapter dried the battery so I decide to order a new one, I got it yesterday and replace it but still same behavior :-(
Do you have any thoughts ? do you need more picture video of something else in a matter to understand better the problem?
Thanks
完成的
添加一条评论
2个答案
已选择的解决方案
Okay, So after many investigation and troubleshooting the problem solved by changing to another power adapter.
Thanks all
这个答案有帮助吗?
得分 1
添加一条评论
Easy fix is always to clean out the MagSafe charging port to get rid of anything that might prevent a good connection. Use a generous amount of mild cleaner and a small brush to scrub out anything that shouldn’t be there.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
purian 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 428
