White smoke from engine bay
I have a 2003 Escape that I noticed started smoking yesterday. The smoke was coming from the passenger side under the condenser somewhere in that area. It smells like something is burning. I do have a power steering leak and am convinced that it may just be fluid burning off the components, but it was pretty consistent and seemed like it was coming from a specific source rather than the general area. I do see oil buildup around the valve cover, so it could need a new gasket, but the smoke doesn't seem to come from that area. The temp gauge stays consistently in the middle of hot and cold. Heater and AC both work great. Coolant level is normal. Please help!
3条评论
THOROUGHLY CLEAN all cited areas. The problem area will be evident on next startup of engine.
由 M. Kohut 完成的
The air have to cool down the engine.
由 Keondra Overton 完成的
@overtonkeondra4 think about this one for a bit. It is a liquid cooled engine and does not need to be air cooled (actually it will not get air cooled) but what are you really saying? Explain to us what you are thinking here.
由 oldturkey03 完成的
