跳转到主内容
Other than the Tahoe Limited Edition, the vehicle was redesigned for the 2000 model year on the new GMT800 platform, still shared with the full-sized pickups and SUV's.
46 个问题 查看全部
How do I disconnect the oil pressure sensor electrical connector?
Because the oil pressure sensor is at the back of the engine on my 2003 GMC Yukon XL Denali 1500 6.0L, I can't see it but can feel it with my hand. I'm having the worst time trying to lift up on the electrical plug's clip with my finger and there isn't enough room to try and fit a flat blade screwdriver back there. Is there an easier way, or some tool that will help disconnect the plug?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
https://www.youtube.com/watch?v=x_yjZ3mC...
Does this help much, if it is the same type of connector release then it appears that you might be able to reach around from either side of the back of the engine, if laying up on the engine, you might be able to reach around with both hands, one from each side. Good luck.
这个答案有帮助吗?
得分 0
1条评论:
If you are going to replace your sending unit, be sure you get the correct type, for example, it has one wire or three wires, it may not be the exact same dimensions for the overall unit, but the connectors are all the same but the number of wires can be different, beware!!
完成的
添加一条评论
添加你的答案
Cullen John Davis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 31
总计 1,689
