My phone doesn't turn on and keeps restarting when I plug it into USB
Hey there, Recently i tried to root my Samsung J6+ using magisk and TWRP recovery but it failed, when i open up the phone it just tells me that i can’t use samsung pass because my phone has been rooted but when i check using root checker there was no root, i tried flashing a new software for my phone but when i was flashing using odin my phone turned off and kept rebooting on a green screen that tells me “An error occured while installing software update”
so now my phone doesn’t turn on but when i plug it into my laptop or charger it just keeps restarting on that screen
when i try to go to download mode without pressing continue it just stays but when i press continue it keeps restarting again and again, Hopefully someone could help me fix it, Thanks.
I would see if you can re-flash the original firmware to the device. Unfortunately your device might be bricked. This typically happens when power is cut to the device while flashing the firmware.
由 Carlos Oulman 完成的
May be ask in XDA J6 forums - more users from Samsung there.
由 Edward C 完成的
Chỉ tôi thay màn hình điện thoại j6+ với ạ
由 Vanquy Nguyen 完成的
