跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 个问题 查看全部
No sign of power on MacBook 2015 Core M.
My MacBook 2015 randomly died and then wouldn’t charge. I removed the back panel, tested the cells and they were reading below 2.9v. I have since removed the battery and installed a brand new one, but there is still no sign of life. I have plugged the MacBook in with a 5W charger as suggested in the iFixit guide, but after a few hours still nothing. LogicBoard Issue??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
Have you gone in with a multimeter and tested for continuity between the power switch, the battery, and the charge port? Im not too well-versed with how the board is wired up in these models, but I would recommend checking to make sure that the battery is even being recognized.
if it’s anything like the chromebooks that I fix daily as a result of my job, I would recommend just charging it all night long and coming back in the morning. Some of the batteries come almost dead and as a result take a day or two to regain their composure so to speak.
这个答案有帮助吗?
得分 0
1条评论:
Hi Shy, thanks for your response. I haven't checked continuity for the power button, as I never thought of that to be the issue. I will check that now. Although when the Mac has reached a sufficient charge it should switch itself on which it hasn't done. I have checked the new battery after leaving it on charge for a while, and the cells show 3.6v, so the Mac should be powering on.
完成的
添加一条评论
添加你的答案
Donald 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 394
