Can not log on or operate
computer screen only shows chrome logo on white screen, when I open thte chromebook, then goes off, no response from touch
Which model?
See this:
Acer Chromebook C720 Solid State Drive (SSD) Replacement
Google/look in youtube - most likely it is a loose contact that SDD is disconnected.
Gently unscrew - check everything like loose cables/connections.
Try.
alternately, the SSD is damaged. Buy an replacement.
See Acer Chromebook C720 Solid State Drive (SSD) Replacement
Post here again…
这个答案有帮助吗?
Model R 13
N16Q10 will not start, or respond to key strokes or touch screen just white screen with google logo
Please help with suggestions
May be the OS is damaged? Do you have any messages
https://support.google.com/chromebook/an...
Can you put a photo of the screen?
Gently open and clean and check all connections are OK.
no, there is no response from keystrokes or touch
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
