跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
147 个问题 查看全部
Can't turn on WiFi, Bluetooth doest find devices.
I recently successfully replaced the digitizer on my iPad 6th Gen (WiFi) after using for about 2 days, the iPad rebooted itself, and now WiFi switch is turned off and greyed out, and Bluetooth just keeps searching for devices and can't find anything. I tried resetting network settings, rebooting my gateway modem, and restoring to factory settings. Nothing worked. What I am wondering is would a bad antenna cause these issues, or if the antenna is bad would I just have crappy reception?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It’s possible that you may have successfully repaired the screen but damaged the connection on the iPad itself. If it’s greyed out from my experience that generally means that someone inside the iPad is damaged. Only way to fix it is to open it up again and check
这个答案有帮助吗?
得分 0
1条评论:
Generally it turns out to be the wifi chip going bad if that's the case the logic board would need to be replaced otherwise time to get another iPad.
It's actually quite rare for these to go bad on iPad air and newer iPads.
Double check the two antenna connectors near the screen connectors on board as they can get unplugged accidentally rare but does happen.
完成的
添加一条评论
添加你的答案
Joshua Holder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 79
