跳转到主内容
Isuzu introduced the five-door Isuzu Rodeo to the United States in 1990 for the 1991 model year.
4 个问题 查看全部
Why cant I go over 50 mph?
I have a 94 rodeo. changed plugs wires filters etc. exhaust is broke and i have no power. it wont go over 50 and i crawl up hill. was told catalytic converter. my question is do i buy new one and fix exhaust or just bore out the old one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Unbolt the exhaust pipe prior to the convertor and see if you gain more power. Does your state have emissions testing? Do you have an oxygen sensor after the convertor? If either question is YES then I don’t recommend to hollow it out, I also don’t recommend an aftermarket part as they normally don’t work properly to pass emission tests. I would not have a problem with a used exhaust system from an original vehicle at the junk yard, I would look at the oil first for normal maintenance from the old owner, engines that burn oil are not good candidates for a used exhaust system.
If you don’t gain power with an open exhaust then a weak fuel pump (low output volume) or bad timing (jumped belt by even 1 tooth) would be the next place to inspect.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lyle_barrett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 208
