跳转到主内容
Who knows about arcade repairs?
Hi. So I got the chance to work on what looks to be a 1980s Midway Ms Pac-man arcade cabinet. According to the owner, it worked fine until every once and awhile, you would need to hit the cabinet for the screen to clear up from random game trash, if that makes sense. But now it has gotten to the point of just showing a screen of trash at boot. I have researched a bit into it and I could be on the right path but I'm no pro at this stuff. From what I can tell, it isn't rebooting so the regular board works I think. It looks like it has a Ms Pacman Aux board on it so I am wanting to say that it could possibly be a bad cable from the main board to the aux board. From what I can find, you can supposedly take the CPU chip from the aux board and put it in the main board and if it works correctly, though it will show a odd looking pacman, then the main board works. Does anybody know someone who works on these things that could lead me on the right path or possibly help? Thanks in advance. If the photos show up, this is what I'm looking at.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@car34 you did not tell us enough about the machine. Anyhow there is a self test mode that the Midways MS Pac_man had. Check for a switch inside the coin door under the coin meter. Set that to the on position. After that check for these things:
Let us know what you find.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Carlos Ramirez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,021
