跳转到主内容
Repair guides and support for the Nikon D800 and D800E digital SLR cameras announced in February 2012.
18 个问题 查看全部
Big front focus (out of the norm)
Hello, Is it possible to correct a front or back focus problem that is out of the ordinary (more than +20 / -20) ?
Bonjour, est il possible de corriger un problème de front ou back focus totalement hors norme (plus des +20 / -20) ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Have you set the viewfinder diopter so that focus is sharp at some point?
Are you having the same problem with manual focus lenses?
I know that modern autofocus lenses can be calibrated, you may want to check the proper technique for doing so. YouTube is your friend for this sort of thing.
这个答案有帮助吗?
得分 0
1条评论:
I'm talking about an autofocus problem, I don't see what the diopter has to do with it.
In manual and with liveview, I don't have a focus problem.
On Nikon D800, it's the general setting that can be changed, but this camera has a problem outside the possible correction level.
完成的
添加一条评论
添加你的答案
MrSoul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 160
