跳转到主内容
A 64.52" LED 2160p 4K UHD Television released in 2015.
13 个问题 查看全部
Tv will not power on.
TV is one year old and all of the sudden, the TV will not power on. I’ve checked the power source and the outlet is not the problem. Any idea what the problem is and where to get it repaired?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I am having the same problem! Did you have any luck fixing it?
完成的
Tyler, having the same issue. Any luck with you?
完成的
添加一条评论
1个答案
最有帮助的答案
@sherribgibson really could be a lot of things. You would always start with the power supply first. In your TV;’s case you do want to check any warranty from whether Vizio or the store you purchased it from. If it is covered under warranty do nothing physical to the TV but holler a lot at the store etc. If it is absolutely not covered you will have to take the back of your TV and check the power board first. Let us know what you find out.
这个答案有帮助吗?
得分 2
1条评论:
I'm having the same issue actually. Checked voltage and seems to have all 19v going out to the main board. Can't seem to find a Standby voltage spot, but did find a wire that was sending 5v over to the main board, while plugged into the power supply. Do you think it may still be a power supply issue, or maybe a main board?
The LED light flashes very quickly when plugging the main adapter, btw.
完成的
添加一条评论
添加你的答案
Sherri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 928
