跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
260 个问题 查看全部
Vertical lines on the display?
Hello,
So I have a MacBook pro late 2016 15” laptop, which is almost unused. It was bought 25 months ago.
It didn’t get any external damage - but all of a sudden I got this annoying vertical lines on the right side of my display (and some horizontal ones on the bottom)
I really don’t get it, as nothing really happened other then me opening my laptop as usual.
Please advice!
Thank you very much,
Shy
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hello
If it was me I would connect it to an external monitor
From what your are saying it may be a fault display so I would be connecting an external monitor to it to see i it has the same issue or not
Let us know please
这个答案有帮助吗?
得分 1
2条评论:
Sorry, didn't mention that I connected it to the tv - and it worked fine. So I assume the problem is with the hardware. I also ran a diagnostic and it came out as everything is fine.
完成的
I leave it now up to the experts here on Macs to take it further There is quite a few so I am sure they will put you in the right direction
完成的
添加一条评论
That's probably a bad display panel, or a bad connection between the display panel and the logic board.
If you don't have AppleCare for the repair to be covered or discounted, then you can take it apart and reseat the display cable. If that doesn't work, you'll likely need to replace the whole display.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shy Buba 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 152
