Washer only wants to drain no lights coming on.
My Kenmore washer only wants to drain. Power button doesn't do anything. Have to unplug washer to get it to shut off. Won't start a cycle. Doesn't want to to anything but try to drain.
If any machine drains only without advancing at any point
this generally means you may have water in flood tray
and or/ pressurestat ( water level switch ) may be at faul
if your machine is electronically managed this may be the cause and or / wiring loom
chatswoodapplianceservices@gmail.com
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 204
Does it fill, agitate, spin, throw any error codes. There is just not enough information to even guess what the issue is. It may also help to know your exact model number.
由 mayer 完成的
It is a Kenmore model 100.20232711. The only thing it wants to do is drain. I started a load and the washer started filling. Then it started draining. But didn't spin. Unplugged it and plugged it back in and it still trying to drain. There is no water in it
由 Tracy Davis 完成的
