跳转到主内容
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 个问题 查看全部
I replaced my laptop battery and now the computer won't turn on
I replaced my laptop battery and now the computer won't turn on, it does turn on with power cable and without the new battery, it also turns on with the old battery plugged in, I also noticed that the battery LED is blinking constantly with the new battery installed
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I am guessing that you cannot charge them up without turning on the laptop?? Make very sure your model number of laptop matches the required battery, its easy to get the wrong one, I just bought 2 replacement batteries and both of them are fine, my only complaint is they only last for 2 hours each.
完成的
添加一条评论
1个答案
最有帮助的答案
Faulty replacement battery I’d assume. I recommend contacting seller for a warranty replacement.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
JPCG 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 46
