跳转到主内容
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 个问题 查看全部
Should I buy the new or upgrade the old?
Hi, in a few words:
Weighting between a DIY upgrade fix vs. buying a new Macbook Pro. Which is the best cost-effective option?
I have a A1502 Macbook Pro:
Processor Name: Intel Core i5
Processor Speed: 2.6 GHz
Memory: 8 GB
Chipset Model: Intel Iris
VRAM (Dynamic, Max): 1536 MB
I need a graphic card like:
1. AMD FirePro D300
2. AMD FirePro D500
3. AMD FirePro D700
4. AMD Radeon R9 M290X
5. AMD Radeon R9 M380
6. AMD Radeon R9 M390
7. AMD Radeon R9 M395X
8. Intel® HD Graphics 6000
9. Intel® Iris™ Graphics 6100
10. Intel® Iris™ Pro Graphics 6200
11. GeForce GTX 675MX
12. GeForce GTX 680
13. GeForce GTX 680MX
14. GeForce GT 750M
15. GeForce GT 755M
16. GeForce GTX 775M
17. GeForce GTX 780M
18. Quadro K5000
Thanks very much!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Boy what a list of GPU’s!!
Most on your list are not used in laptops at all. So let’s trim it down. Are you committed to a laptop or is a desktop workable for you? Maybe you need both!
You also list off intergraded graphics engines as well as dedicated GPU’s which doesn’t make sense. Again pull these out.
Now focus! What is your direction Laptop or Desktop? What are you doing with your system?
As an example… I have a MacPro 2013 for my photo editing (working on RAW images). I also have a 15” MacBook Pro retina 2015 which I use when I travel to review my pics. I had a 17” which died while it was much slower, the size of the screen offered more to visualize what I was working on. I’m waiting for the coming 16.5” model (at least thats what’s rumored). As I really need both screen and processing in my portable.
I also have a different set of systems which I use for different tasks! A 27” iMac and an older 15” 2012 MacBook Pro as I need those old fangled ports! And I don’t want dongles or hub devices!
Apple made a left turn with the current MacBook Pro’s with Touch Bar where the heavy Pro’s like me are still aiming straight and waiting for Apple to get back to the straight line of what Pro’s need! Ports must be on the system! USB-A, Ethernet & SD slot are still needed and we want the next Gen of MagSafe for power leveraging the back two USB-C ports (x4) recessing them so a MagSafe plug with charging LED can be fitted flush with the case.
So what is your needs?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
xavest 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 68
