跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2191 个问题 查看全部
Hi. my iPhone 4s droped on water
hi .my iphone was droped on water and i try to fix it by open the phone and dry it and clean it but after that when I try to turn the phone on its stuck on the logo apple and turn off and turn on and doing that all the time .what I can do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Ziko link you are not telling us how and what you cleaned. The first thing I suggest is that you disassemble the phone using these guides. Then clean the phone with +90% isopropyl alcohol. Use this guide to clean it. After you have everything properly cleaned, replace the battery Reassemble your phone and re-evaluate. Once you do all that let us know what you found out. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ziko link 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 22
