跳转到主内容
加入维修社区 - 创建账户
Nvidia Shield Tablet 第一代于 2014 年 7 月发布。该设备通常用于游戏,具备 Wi-Fi 和 LTE 功能。
I wiped my hard drive by mistake
would that get me access to the tablet again ? currently i cant access it as i wiped it and cant recover it. Or will replacing the mother board do nothing and put me in the same boat im currently in now -with having to reinstall the OS ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
is the recovery partition still on the device?
由完成的
no sadly i wiped it :(
由完成的
Yes by replacing it you be running again
由完成的
My next question is replace the motherboard or trying to flash the current one that has been wiped ? I mean there must be a way to flash it..no? They do it at the plant I literally have a clean slate hd/motherboard there must be a way to flash it ...if I can't is the original Motjerboard 2015 shield the same is the shield k1 version circa 2017
由完成的
添加一条评论
1个答案
Start with this in fastboot mode:
https://twrp.me/nvidia/nvidiahshieldtabl...
Flash the TWRP - then you can search XDA to get a ROM to flash https://forum.xda-developers.com/shield-...
https://wiki.lineageos.org/devices/shiel...
Recovery: With the device powered off, hold Volume Down and tap Power, then release once menu is displayed. Tap Volume Down until recovery is selected. Press Power to select.
Download: With the device powered off, hold Volume Down and tap Power, then release once menu is displayed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 641
