跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 个问题 查看全部
Removing screen on iPad mini
im trying to change the battery on an iPad mini. I watched a video and it said I need to use a heat gun to remove adhesive. can I use something else other than wheat gun? I don’t want to have to buy one. maybe a hair drier? I know someone that put theirs in the microwave with something on it to remove the screen. Im not sure what to do. thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
A hair dryer may work fine. All you are trying to do is soften the adhesive. Caustion should be taken to prevent over heating the display as it can cause white areas on the display from over heating.
Putting electronics in a microwave will destroy it. The someone you refer to has a dead machine. You do not put metal into a microwave. What they probably put in the microwave was a heat bag which is then laid on the edge of the iPad to gently heat the adhesive.
iPad Mini CDMA Battery Replacement
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
salma lentini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 42
